    Dismiss Notice
My Triton Electric Shower cuts off approx 5 minutes run time COLD or Hot
Discussion in 'Plumbing and Central Heating' started by DIWHY, 8 Jul 2021.
  1. DIWHY
    DIWHY
    1 May 2005
    80
    Thanks Received:
    Lancashire
    Country:
    Please help me its doing my head in.
    Everyone just assumes HOT overheat trip out with thermo BUT NOT
    It trips out when set JUST just running COLD approx 5 minutes every time
    Tested it all afternoon running JUST COLD trying to flush (hopefully Woefully) and it still stops running approx 5 mins in.
    ALL electrics are live and connected
    WHAT is it thinking inside ?
    Thanks for all.
  2. Sponsored Links
  3. just pumps
    just pumps
    24 May 2016
    2,984
    Thanks Received:
    507
    Country:
    Something in the box is overheating and shutting down.
  4. terryplumb
    terryplumb
    8 May 2017
    6,164
    Thanks Received:
    1,278
    Country:
    What model of Triton shower do you have ? When it cuts out ,does it start up again after a while ?
  5. DIWHY
    DIWHY
    1 May 2005
    80
    Thanks Received:
    Lancashire
    Country:
    Thanks Guys
    Hi JPumps What is overheating when its set to run on only Cold setting. My mains water is brass monkeys no chance of any heat there.
    Hi TPlumb Model is Triton Seville it will restart after just a few minutes. I've just had it running for 10 minutes but then cut, so annoying.
  6. CBW
    CBW
    26 Sep 2019
    9,060
    Thanks Received:
    2,422
    North
    Country:
    By itself or manual intervention?
  7. just pumps
    just pumps
    24 May 2016
    2,984
    Thanks Received:
    507
    Country:
    But current from the supply is passing through the shower. Have you heard of showerdoc.com or contacted them, they are good for advice and parts.
    • Like Like x 1
  8. DIWHY
    DIWHY
    1 May 2005
    80
    Thanks Received:
    Lancashire
    Country:
    Hi Guys ,
    CBW I restart myself. I switch off and isolate as I'm not sure what is tripping and would be still active. Then restart from fresh.
    JPumps see what you mean malfunctioning electrical heat, yes I'll try showerdoc.com Thanks
  9. CBW
    CBW
    26 Sep 2019
    9,060
    Thanks Received:
    2,422
    North
    Country:
    Tripping? Does it trip the mcb on the consumer unit, or is it just cutting out? If the latter then it could be voltage or solenoid related.
  10. Sponsored Links
  11. ianmcd
    ianmcd
    15 Aug 2010
    23,511
    Thanks Received:
    9,711
    Lanarkshire
    Country:
    check your pull cord switch , it is common for the terminals to slacken off and Arc when in use, this would cause heat whether shower was hot or cold
    • Thanks Thanks x 1
  12. DIWHY
    DIWHY
    1 May 2005
    80
    Thanks Received:
    Lancashire
    Country:
    CBW No actual trip MCB its still set, all led red lights on pull switch and unit stay alight the water flow just stops
    Ian Pull cord switch looks and feel ok
    I just think it very odd that the water cuts off when even just on Cold setting it runs now 5 to 10 minutes and then trips
  13. CBW
    CBW
    26 Sep 2019
    9,060
    Thanks Received:
    2,422
    North
    Country:
    Could be solenoid failing
    • Like Like x 1
  14. ianmcd
    ianmcd
    15 Aug 2010
    23,511
    Thanks Received:
    9,711
    Lanarkshire
    Country:
    it still uses electricity even when only running cold water, not as much as when hot but it still uses it
    • Like Like x 1
  15. ianmcd
    ianmcd
    15 Aug 2010
    23,511
    Thanks Received:
    9,711
    Lanarkshire
    Country:
    Stop saying that it "Trips" that means something completely different, it merely stops
    • Like Like x 2
  16. Alec_t
    Alec_t
    18 Mar 2017
    758
    Thanks Received:
    132
    Wales
    Country:
    Could low water-pressure, or a faulty water-pressure sensor, be the cause?
  17. jeff the gasman
    jeff the gasman
    8 Dec 2007
    13,752
    Thanks Received:
    5,070
    Cheshire
    Country:
    As @CBW stated. Solenoid going open circuit.
    • Thanks Thanks x 1
Loading...
Share This Page
