Need schooling changing fuse , as upstairs lights won't work
29 Dec 2012
Belfast
firstly hello and thanks in advance ...also hope you had a good Christmas and will have a smashing new year
now lets talk brass tacks:
upstairs lights are not working , but sockets are .....
i have 'ATTACKED' the fuse the box as a first inquiry and found this to be the issue
i switched over fuses for downstairs to upstairs lights ( same amp ) and all lights came on ...
i need some tutelage , in regards to to why my fuse is not working , as it has no fuse in it , from what i can see ........ ( see pics )
the fuse box is in a house i don't use , my house i live in ... i usually just pull the casing down and there is a fuse in it , then i just replace it ...... as you can see from this one ..... it has no fuse anywhere .... is the the whole unit the fuse ?
the brown bit on the fuse , is like porcelain...with a hollow hole .... and two little screws fixing it the base unit ....
do i just replace the whole unit ?
my fuse box ( sorry i don't have the picture ) is a memera bs 5486 pt 13
by the looks of it , it probably is an antique , and not like those i have seen in previous houses
so in summary ..... do i replace the unit? as when switching pully out things with downstairs and upstairs all worked fine
or is there an actual fuse someone within the main fuse box ?
i would also just out of pure curiosity like to know who this unit works
like i said int he opening thanking you in advance
stevearno
That is a rewireable fuse.
You need some 5 amp fuse wire.
You need to loosen (but not remove) the two screws and remove any bits of old fuse wire.
Then thread a piece of new fuse wire through the ceramic tube, and wrap it round each screw once, and tighten up the screws.
Be careful not to make the fuse wire too tight or it may break when you tighten the screws up.
Remove any excess fuse wire which may be sticking out from under the screws, and that's your fuse all fixed.
When you have done, you will probably find that one of the upstairs lights does not work.
That is because the bulb has blown. That will be what scrogged your fuse. So you'll need a new lamp in that fitting.
thanks guys ..... for the quick and easy explanation
Taylortwocities... a blown light in the upstairs ... will it just be the bulb in the ceiling that needs to be replaced ?
the lights that have been knocked out , are just the ceiling and wall lights ..that don't have fuses
NOT the sockets
again thanks guys
stevearno
yup just the bulb, one of them just won't work when you turn it on and the others upstairs work
One heck of a surge from a failing lamp to take out a rewireable.
Steve - how much lighting do you have on that circuit, and how much of it was on when the fuse blew?
One heck of a surge from a failing lamp to take out a rewireable. Steve - how much lighting do you have on that circuit, and how much of it was on when the fuse blew?
True, but I've known it to happen (invariably at switch-on) in the good-old days of lighting circuits loaded to the teeth with incandescents - particularly if many (including the about-to-die one) were switched on simultaneously with a single switch.
Kind Regards, John
