Hi
I have a Vaillant ecoTec Pro 28 combi boiler which currently operates with a Honeywell wireless programmer and a Honeywell BDR 91 relay box. I'm thinking of replacing the Honeywell controls with a Nest 3rd Generation Thermostat and trying to determine whether or not i need to get it installed professsionally.
I have looked at the wiring in the BDR91 and note it is wired as follows :
1 Black wire connected to Neutral
1 Black wire connected to Live (middle in photo below)
1 Black wire connected to B
1 Green/Yellow wire connected from Live (middle) to Live (right)
1 Green/Yellow wire connected from Live (right) to A
(I assume that although the electrician that originally installed the Boiler and Honeywell system used Green/Yellow wiring, they are not actually earth cables and that he should have covered them with the proper colour tape so that they could be correctly identified).
The 3 black wires will i assume simply connect to the Nest Heatlink unit as follows
Honeywell (Black) Neutral - Neutral
Honeywell (Black) Live - Live
Honeywell (Black) A - 3
What action is required regarding the Green/Yellow wires in the Honeywell ? How do they convert to the Nest unit? I was under the impression that a wire would be required at connection 2 on the Nest.
I'd be grateful for any advice. I've included a photo of the original BDR91 wiring diagram, one of the actual wiring in mine and a sketch in case the photo doesnt show clearly where each wire is connected.
I will probably still get an professional installation as i'm guessing they would rewire it directly from the boiler using the correct cables/colours but in the meantime i'd like to try and get my head arround what the correct wiring should look like.
Harry
Harry
