I think that's probably right. If you do need a new CU (for reasons other than the material it is made of), then it makes sense to get one which is going to be compliant with the current regulations come next January. Unfortunately, as per the 'technical' discussion here, I think that almost certainly means that you'll be stuck with a metal one, since I don't think you (or, rather, your electrician) will be able to find a plastic one which claims to be compliant with the new regulation.Thanks for all the comments, this thread has got a bit technical for me now! But it seems the consensus is I do need a new consumer unit as want an electrical shower fitted, and if want to keep up with regulations coming into place from 1 January 2016 should consider getting a metal CU?
You are right to be concerned. The "Part P council notification" is not optional. Replacing a CU is 'notifiable work' and if your electrician does that without notifying it, he will have broken the law, and left you in a potentially difficult position. He therefore should not be implying that not notifying the work would be a (legal) option. As for the charge, it could just be that he is being 'too honest'. As you say, there would not usually be a separate charge for this. However, dealing with the paperwork etc. takes a little time, so I presume that most electricians 'build that in' to their quotation/estimate without mentioning that trhey have done that - but maybe he hasn't. I would have thought that it's unlikely to be anything like £90's work, anyway. Your best option would really be to get one or two other estimates/quotes and see how they compare the the present one (with and without the £90 added).Another quick questions...one quote I received said: To supply a satisfactory NICEIC certificate with Part P council notification. £90.00. That seems a lot to me and research online seems to say this should be included. When I questioned what the charge for the certificate was for he added 'The advantage of the certificate if that if you want to rent the property in the next 5 years you have it in place, if you are going to live there then there is not a great advantage to having the certificate to be honest.' Still, should I be paying for this if we do plan to rent in the future and if so, £90 seems a lot or is that standard?
Kind Regards, John
