New floor advice needed
5 Mar 2018
France
Hello I am not new to the forum but have not posted for a long time and had to create a new account as my email has changed... but I am now in need of more help. So any advice is most welcome!
I have an old house down in France which is made from round stones and mortar, which is sometime stronger in some places than others. Anyway I have a 5m x 3m store room that currently has just a mud floor which I would like to create a floor in. The walls in this room are in good condition and i think the mortar is quite strong also. I had thought about a concrete floor but getting the material into the site would not be easy and I suspect the delivery cost would also be high as we are about 35km from the nearest supplier. So I have an idea that one way of making this floor would be to use timber joists and chipboard flooring. The main question I would ask is this is it sensible to fix my main bearing timbers to the walls using some expanding anchoring bolts through the timber into the mortar of the wall? The timber I will be using is all 63mm x 175mm. I thought that if I fixed a 5 m x 63 mm x 175mm to each wall and then used 3m x 63mm x 175mm joists at 500mm centres and topping it off with 22mm chipboard flooring I could make a stable floor? This would not be a high traffic area I would probably be using it as a store/workshop. The reason I want to use bolts to fix the timbers is basically to save my body from heavy work involving foundations and the like... I am not getting any younger :)
any help from the experienced would be most appreciated
thanks
John
