Under the lease, I'm the Tenant. The owner of the freehold is defined as the Landlord. But, because the lease term is 999 years this just seems to confuse everyone here, so don't worry about it.Are you the Landlord or the tenant?
No, I didn't imply that at all. What a stupid comment.Erm, did you just imply that demonstrating capacity for changing a light bulb puts you on par with a qualified electrician?
I suppose, by the same measure, cutting your child's nails proves you ready for a career as a paediatric surgeon?
At point of entry to the premises - might be in the kitchen.The other work which I'm told needs doing is bonding of the water and gas pipes in the kitchen.
That won't be necessary any more if you have RCD protection on all the circuits with the new CU and a couple of other conditions are met.I had this done some time ago in the bathroom and understood the need.
No, unless as above.Is it necessary in the kitchen though?
Before or at the same time makes no difference.I'm slightly surprised at the cost. One of the electricians said that this should be done before the consumer unit is replaced. Is that correct? I don't see why.
Typically when people talk about landlords and tenants with regards to domestic properties they aren't talking about the freeholder (typically a management company)/leaseholder (typically a person who is registered as owning/paying a mortgage on a residential unit) but instead a leaseholder/shorthold tenant (someone who lives in the unit under contract but does not "own it")Under the lease, I'm the Tenant. The owner of the freehold is defined as the Landlord. But, because the lease term is 999 years this just seems to confuse everyone here, so don't worry about it.
1st line of the 1st post!I don't recall/didn't read back to see how you introduced it but this could be the source of confusion
All the fault of MacFarlanes solicitors who drafted the lease back in 1979 then:Typically when people talk about landlords and tenants with regards to domestic properties they aren't talking about the freeholder (typically a management company)/leaseholder (typically a person who is registered as owning/paying a mortgage on a residential unit) but instead a leaseholder/shorthold tenant (someone who lives in the unit under contract but does not "own it")
I don't recall/didn't read back to see how you introduced it but this could be the source of confusion ..
Is it not the case with every single leasehold property? The last I knew this accounts for something approaching 20% of new build housing making a significant rise to the current ~ 25% of domestic dwellings being leasehold. Many newbuild customers don't even know they are leasehold.Typically when people talk about landlords and tenants with regards to domestic properties they aren't talking about the freeholder (typically a management company)/leaseholder (typically a person who is registered as owning/paying a mortgage on a residential unit)
I am in the position of being a freeholder/landlord to STL tenant on one property.but instead a leaseholder/shorthold tenant (someone who lives in the unit under contract but does not "own it")
What confusion?I don't recall/didn't read back to see how you introduced it but this could be the source of confusion ..
If I recall correctly ..... I think that what in everyday language is called a "Leaseholder" usually is, in legislation and legal documents, referred to as a "Tenant". ... and that would be consistent with the Lease from which Arbu has quoted.Typically when people talk about landlords and tenants with regards to domestic properties they aren't talking about the freeholder (typically a management company)/leaseholder (typically a person who is registered as owning/paying a mortgage on a residential unit) but instead a leaseholder/shorthold tenant (someone who lives in the unit under contract but does not "own it")
It is nothing to do with it being a kitchen.The electrician said that this solves pretty much all the C2s on the EICR except that for the lack of bonding to the water and gas in the kitchen. He says that this requires trunking all the way from the fuse board to the kitchen. This is a long way, and is going to be unsightly. I already have bonding in the bathroom, which just goes from the radiator to a light fitting, so I'm puzzled as to why it needs to be different in the kitchen.
I doubt that but it is irrelevant anyway.The freeholder/insurer might insist on it, but it seems like none of their business.
Yes.Do I really need it for my own protection?
OK, I'm now the proud owner of a Wylex NM Range Flexible Busbar BSEN61439-3. The electrician said that this solves pretty much all the C2s on the EICR except that for the lack of bonding to the water and gas in the kitchen. He says that this requires trunking all the way from the fuse board to the kitchen. This is a long way, and is going to be unsightly. I already have bonding in the bathroom, which just goes from the radiator to a light fitting, so I'm puzzled as to why it needs to be different in the kitchen. The freeholder/insurer might insist on it, but it seems like none of their business. Do I really need it for my own protection?
No, it is part of the job when replacing a consumer unit.So are we saying that now that I have had the fuse box updated, I am obliged to get the bonding done,
How can we know?and I won't get the part p certificate until this is done?
Because that is different. That was supplementary (extra) bonding in addition to the main bonding (at point of entry).And why did the previous bonding that I had done in my bathroom from a radiator pipe only have to be to an earth point on a light fitting and not the main entry point?
