New governor required for gas meter - who does it?
30 Jan 2011
Middlesex
Worcester Bosch came out to check for a leak on my newly-installed WB 30CDi boiler recently. The boiler was fine and the leak was eventually found to be in an elbow joint under the living room floor.
However, the WB engineer did a thorough test of the WB 30CDi boiler and this included checking the gas supply. The gas meter is located within 2m of the boiler.
He checked the gas flow rate and it was below the minimum required for the WB 30CDi boiler - not by much, but still below.
WB will revoke any warranty/guarantee on the boiler if I don't get the problem fixed. They say that the governor in the gas meter needs to be changed to allow a higher flow rate.
I have several questions on this issue.
1. Should the original installers be held accountable is WB revoke my 5-year guarantee on the boiler? They are WB registered and, surely, they should have checked my gas flow rate was within specs for the boiler?
2. I phoned Southern Electric (who also supplied my gas) and they said I need to contact National Grid. I phoned National Grid and they said I need to contact Southern Electric. Who is responsible for changing the governor on a gas meter?
14 Jul 2007
Cambridgeshire
Transco to change governor,
What was the working pressure at meter when boiler running on max
You might not be getting another gas to the meter to supply boiler.
I installed a vaillant 837 in my own house, was only getting 13mb at meter.
Transco came out fitted and supplied new gas pipe to meter, they also relaid slabs they had lifted.
25 Nov 2007
Oxford
Had a similar problem with our system a few years ago. Suddenly noticed that boiler wasn't heating very much, and that hob went out when boiler fired up.
Transco came and sorted it in 30 mins flat!
28 Mar 2006
Hedge End Hants
probably find you have a sleeved gas main (plastic through the old metal pipe) just ring 0800 111 999 tell them that you aren't getting enough gas through to your boiler / cooker they will attend within the hour and will sort them problem quickly and properly (always had 100% service from SGN)
10 Jun 2009
Suffolk
Another Unhelpfull WB Engineer Then!!!!! :LOL: :LOL:
A Decent RGI would have contacted Transco for you there and then to save you the hassle!! :rolleyes:
Perhaps WB do allow there engineers to go the extra mile!! :LOL:
