Hi all,
Having read through the highly useful FAQs & some previous posts I think I have diagnosed that I have insufficient pressure in the expansion tank of my sealed central heating system - this is resulting in cold rads on the second floor (modern townhouse). Initially tried to bleed the rads (as they are warm at the very bottom) but only get a momentary release of air and then nothing.
This is the hot water cylinder / controls / expansion tank:
So this was the pressure reading just now with the system running and at full temp, am I right in thinking this should be 1 bar with the system off and higher again with the system running?
To top it up / re-pressurise I believe I need to open the two black valves shown in this photo:
Is this correct?
Also the tank thermostat looks like it is set too low to me? I have read it should be ideally at 60^C - but if this is the case why produce a thermostat that has a scale of 25 - 65?
Any help or advice is much appreciated.
Regards,
Tom
Is this correct?
Regards,
Tom
