New pressure reducing valve
It will lower the pressure when in use but after using an appliance then pressure dial just keeps rising. So can't set to 3 bar.
That's the valve. Pressure just carries on rising to maximum
Can you just get a very small flow from it and see what pressure does it then show. What pressure is set to. (looks like 3.0bar)
Also the Predator is NOT a drop tight PRV which means the pressure will rise to the full upstream pressure with no demand.
Drop Tight PRVs (there are probably more)
Caleffi 535
Reliance 312 Series
Honeywell D05
Honeywell D06
NON Drop Tight PRVs
Caleffi 533
Reliance Predator (PRED800015)
Honeywell D04
Thanks so this pressure reducer don't protect the house from high mains pressure when no appliances are getting used? It will just let the pressure get to the pressure would be anyway without a pressure reducer fitted?
Thanks I've just looked online and it suggests the predator is of the drop tight kind. I've fit one before to protect a water heater from 7 bar pressure and it held at 3 bar.
