you mean will not pass NICEIC for new CU till rewire the lightingIt could be noted as a departure, provided there are no class I items connected to the circuit and appropriate warning labels are added to the consumer unit.
The real solution is rewiring the circuit, as no CPC makes it at least 55 years old.
Think you might need to explain that a little more. Are you using this job to be assessed before you become a NICEIC DI?you mean will not pass NICEIC
no i have already passed it 4 weeks ago home but i just not too sure about the job i came cross and this will be my 1st time issue a certificateThink you might need to explain that a little more. Are you using this job to be assessed before you become a NICEIC DI?
Eric has this idea that it is acceptable to wire a UK installation according to the requirements of some other country's regulations - but I'm not really sure where that comes from.German sockets are unshuttered. Are you so sure they would be allowed?
0.2 A way of satisfying the fundamental principles would be to follow:
a. the technical rules described in the bodyof BS 7671:2001 as amended or in an equivalent standard approved by a member of the EEA; and
b. guidance given in installation manuals that are consistent with BS 7671:2001, such as:
i. the IEE (Institution of Electrical Engineers) On-Site Guide;
ii. the series of IEE Publications, Guidance Notes Nos 1 to 7.
Ah, yes ... I thought there was something like that in Approved Doc P, but, befgore I replied to winston, I only looked in the 2013 version and, as you say, it doesn't appear to be there.I believe it came from approved document P. Specifically, the original version of approved document P said (empahsis mine). .... That text is present in both the "2006 edition" and the "2006 edition incorporating 2010 amendments", however there does not seem to be any corresponding statement in the "2013 edition".
German sockets can be shuttered but they are not polarised, so under BS 7671 not allowed, as to now we have left EU may be no longer allowed, but when we were part of EU we had to permit wiring to any other EU standard, the law did not say must be to British standard.Eric has this idea that it is acceptable to wire a UK installation according to the requirements of some other country's regulations - but I'm not really sure where that comes from.
'The law' never has, and still doesn't, say that UK electrical installations have to comply with 'British' (or any other) Standards.German sockets can be shuttered but they are not polarised, so under BS 7671 not allowed, as to now we have left EU may be no longer allowed, but when we were part of EU we had to permit wiring to any other EU standard, the law did not say must be to British standard.
It doesn't matter as long as an appropriate OPD is on the line conductor.German socketscan be shuttered but theyare not polarised,
I suppose that depends upon what you mean by 'matters'.It doesn't matter as long as an appropriate OPD is on the line conductor.
