I have have just moved into my house and the old owner has taken the built in oven and hob. As needing somewhere to cook just been down to B&Q and bought a whirlpool oven and hob. Oven is rated at 2.3kw and hob at 5.8 kw.
The cooker switch in feed via 10mm twin and earth about 10m in length to a 40a mcb on the consumer unit. From the cooker control switch more 10mm twin and earth cable goes to the cooker outlet plate. Is it possible to wire the hob and oven into the same outlet plate(oven does not come with a plug) or will i need to get a few other bits and bobs to wire it in.
Thanks in advance.
Thanks in advance.
