No water to bathroon toilets basins and baths
25 Jan 2009
Leicestershire
I looked at the large header tank in the loft, it was 1/3rd full (outlets well below water level), and float suspended in mid air. I thought it may be the valve so I switched the isolation valve off and replaced the valve. Switched it back on again and still no water feed. Any help/advice appreciated.
My guess is that your cold taps are mains feed and the hot taps are tank feed.
Check to see if you have cold water at your kitchen tap, check your neighbours to see if they have water.
Andy
Hi Andy ...again !. This time the problem is in my home. I live in a very old cottage that was part of a larger house that has been split into 3. It appears that I have 2 mains feed, some of my house cold water outlets work (Kitchen sink, showers, bath) but others don't (3xwc's and 3 basins).
Found out that a stop cock in the road has been turned off! cannot switch it back on til I check with my neighbours :-).
Thanks again for your sound advice.
Kes
Just found out they are away for the weekend. I will talk to their maintenance man to see if he has been doing work there - doubtful though as they surely wouldn't have gone away. :?
Confirmation ... it was the stopcock in the road that caused the problem. Why it was turned off is a mystery. Andy, you are a star! , guys around you must be so lucky...thanks again.
[quote="Kessa";p="! , guys around you must be so lucky...thanks again.[/quote] Indeed - he seems like a nice boy to me :P
Whoops !!
