It's essentially a semantic issue, but I suppose it's true that everything which is not indisputable 'fact' is, in some senses, an 'opinion'. However, if one is going to say that nearly all statements are 'opinions', one has to remember that there is a whole spectrum - varying from opinions based on very strong evidence to those based on no real evidence at all, and I would suggest that the extent to which we 'take notice' of opinions should depend on where they fall in that spectrum - and I personally don't think it desirable that such opinions be presented as assertions, particularly at the 'lower' end of the evidence spectrum.
It's a socket, which by necessity has holes in it for the plug prongs. .... The holes are too small for normal fingers to fit into ... The shutters are there to prevent other objects being inserted.
All true.
To overcome that protection, it's a deliberate act to overcome the shutters by some method and also deliberately shove inappropriate objects into the socket holes.
Even if that were true, it would not be a reason to discount that possibility, particularly where children are concerned. However, in reality there does not necessarily have to be a 'deliberate act to overcome the shutters'. You must surely have come across shutters that were (not 'deliberately') damaged, non-functional or jammed open - I am a mere DIYer, hence with limited experience, but I have certainly seen such things.
Entirely unrelated to insulation of a cable, which can be worn through, cracked or otherwise damaged in a single inadvertent act.
The 'failure' of shutters can be a single inadvertent happening.
Whatever, as I've said, we generally try to avoid situations in which a danger can arise as the result of a single event/act/happening. If the shutter has (for whatever reason) already 'failed' just one further act can invoke the danger.
No doubt because no one has ever bothered to investigate such things, as the primary function of such devices is to make money by selling items which have no purpose. Those that make and sell them couldn't care less about any effects, beneficial or otherwise.
That obviously is definitely an 'opinion' and I have no information which helps me to know how correct it is - and I imagine the same is probably true of you. It wouldn't surprise me if those who originally conceived the idea sincerely believed that they were useful products which might reduce injuries and deaths.
Sometimes common sense prevails, in not allowing a pointless device to be used.
Who knows. If it was done for the reason you suggest, they must (should) have had some reason to believe that they are 'pointless devices' - unless you are suggesting that they did it 'blindly' solely as the result of the representations of a pressure group?
Some evidence exists showing that they can be broken off in the socket ...
I haven't seen that evidence but, if it does exist, I would have thought that it would be pretty difficult to break off just the earth 'pin', or just the N and E pins?
or shoved in upside down to open the shutters.
If the socket is such that that can be done with one of these devices, the same could presumably also be achieved using a BS1363-compliant plug, and even the NHS could not 'ban' the use of them!.
Some people might be. Others less so.
We live increasingly in a 'blame culture'. Whenever anything 'goes wrong' there is seemingly an obsession to find people to blame (often with the idea/hope of financial gain), not to mention the lawyers who seek to make money out of the situation.
Such requirements have no place in BS7671, and that particular entry should never have been added to it.
I'm pleased to hear that our opinions are the same about that. The reason we both have that opinion is presumably that neither of us has seen any reasonable evidence that 'non-combustible' CUs would offer a significant benefit (let alone 'necessity'). However, if we were presented with reasonably strong evidence that there
is a benefit, then we hopefully would (should) consider changing our opinions,
That's one thing we haven't discussed - the fact that opinions certainly do evolve/change over time, usually as a result of increasing knowledge (hence 'evidence'), and also that there has been an increasing awareness of the need for 'evidence-based' practices. That has been particularly true in relation to disciplines I have been involved with, in that many of the things I was taught (as 'facts') 50 or so years ago were 'opinions' based on historical traditions, mis-applied 'intuition' and sometime even 'superstitions', with little (if any) fact/evidence base. However, in many cases, subsequent increases in knowledge/evidence have shown that those teachings were just plain 'wrong'. Even at a personal level, I'm sure that, although I have always acted 'in good faith' (in relation to then current knowledge/evidence) I will have 'done harm', probably including contributing towards some deaths, as a result of deficiencies in the then current level of knowledge/evidence.
If consumer units are to be made 'non combustible' whatever that might mean, then that and any other requirements should be put into the standard(s) applicable to the construction of consumer units.
That's really just an operation/administrative/'bureaucratic' difference. I have yet to see any good evidence that there is a good reason to include such a requirement in
any Standard (or any 'regulations').
No matter what our opinions, it's presumably too late to do anything about the requirement for 'non-combustible' CUs but we are, at least in my opinion, now seeing the same sort of situation arising with SPDs, with AFDs (and goodness knows what other future technologies) not that far behind. However, in these cases I think that your opinion is in support of at least SPDs, isn't it?
