oak door
8 Feb 2010
Glamorgan
We have had 4 oak doors hung recently.They can be waxed or oiled. My husband gently rubbed down the first one with fine grain wire wool and then hoovered up the dust and the door and wiped it over with a damp clean cloth.tThe following morning the door was covered in a fine black residue.We have tried to use the wire wool again and the door is better but still not as it was.Any advice please as i do not want to start applying wax with some dark areas still on the door
DO NOT use wire wool on oak. Both the water on the cloth and the tannins in the oak will cause any minute bits of wire wool that get into the grain to rust and form ferrous oxide which is whats making the black stains.
Get a grey scotchbrite pad (bit like a green pot scourer) and wipe down with a cloth moistened in meths or buy a proper "tack cloth"
Jason
A tack cloth is a slightly sticky cloth for removing fine dust after sanding. You can get one from any decorators merchant or i'm sure B&Q etc as well. May be in the wood finishing section if not in decorating
Another point worth noting. What screws and fittings have been used? If any are steel they should be removed and replaced with brass. Steel will stain the oak to blue/black.
