I have 3 halogen 12w lights in my bathroom. One is not coming on so i replaced the bulb, but it is still not coming on. Can you help? Thanks in advance
Pull the fitting down and check for burn marks, and tighten connections. Try again.
If no success,
Pull the fitting down and try to find a transformer close by. Should be able to pull it through the hole. Check for damage, tighten connections. Try again.
