    Dismiss Notice
Osmo oil on wooden tabletop
Discussion in 'DIY Disasters' started by Kevin Hart, 31 Aug 2018.
  1. Kevin Hart
    Kevin Hart
    31 Aug 2018
    2
    Thanks Received:
    Country:
    I’m a new boy on the block and have come looking a bit of advice.
    Well it’s not actually a disaster I have but help would be appreciated.
    I’ve a round wooden table top addition to my kitchen island. I’m sure you e seen the type I mean. Anyway I decided to get rid of some watermarks and minor scratchers so sanded the whole thing down until all the blemishes were gone, then applied Osmo top oil.
    The problem is I think I’ve applied to much - four coats, and I think it would be true to say I overdone it with the last coat, it is now obvious that there is to much Osmo on the wooden top. The question is; what to do?
    I’ve picked this up from the Osmo site and it seems to describe my difficulty
    OK I have excess and it has dried could anyone give me a little bit more detail advice as to what to do with the methylated spirits
    As I indicated above this is a first post, so fingers crossed some of you can help
    Kevin
  2. Sponsored Links
  3. securespark
    securespark
    11 Jan 2004
    33,621
    Thanks Received:
    1,022
    Country:
    Is there a portion of treated area that is out of sight?
    What I'm getting at is that you could treat this area with a clean lint-free cloth that has a smidgeon of meths on it, rubbing very gently and then checking on the surface and the cloth to see how it is progressing.
  4. Kevin Hart
    Kevin Hart
    31 Aug 2018
    2
    Thanks Received:
    Country:
    OK I took the bull by the horns and with a deep breath
    Applied a coat of meths and gently rubbed it in. Then sanded the top with 120 grit sandpapergoing in a circular fashion, then took my polishing cloth to it
    I could see that a lot of the sticky residue remained but a lot had gone, or almost gone. I repeated the process with the same result a third and finally a fourth go. I’m sure I could have completed the task much quicker if I had sanded a bit bit more and a bit more virgously but I didn’t want to take any chances. The jobs still not 100 percent but it’s still better than it was before I started !
    The one upside was that if things really did foul up I could always have started over again
    Lesson learned!
    Kevin
Loading...
Related Threads
  1. Ratty80
    6
    2,404
Share This Page
