- Joined
- 9 Dec 2025
- Messages
- 6
- Reaction score
- 0
- Country
Hi All!
I'm now in the process of digging the foundations out for my garden room. The plan is to make this from SIPS construction which will sit on top of rows of 140mm wide block (which is sunken underground and will be waterproofed!) up to ground level with the raft foundation slab acting as the floor (40cm below ground level) Anyway, I had a question about the raft foundation.
While digging I've realised that the clay subsoil does not start until around 70cm into the ground. The plan currently is to dig 80cm deep, lay 200mm of MOT type 1, another 200mm of concrete which will be reinforced with mesh. For the edges of the slab I will dig 1m deep and the concrete will be 400mm deep and 300mm wide.
I do have a couple of trees close to the foundations (within 1m). One is a cooking apple tree and the other a plum tree. Does the plan above sound viable? I'm trying to avoid subsidence/heave and hoping the plan above can support the load from the building.
