Hello All,
I have fitted my new outside lights to the wall and have been busy chasing walls ready for my electrician.
The instructions for the new fittings specify ;
"Do not wire this fitting into the lighting circuit. Use a switched fused spur"
It doesn't quote any standards or regulations & I bought the lights from Homebase.
Is this normal? I had only allowed a backbox for a four way light switch from the lighting circuit for internal and external lighting for the new hall.
The outside lights are 5W low energy bulbs.
If I do need to follow this instruction, would it be ok to fit a switched fused spur above the chase for the four way switch, and still switch the lights through my four way switch, after the spur? (I would fit a 3A fuse to the fused spur)
Any opinions would be gratfully recieved..
I was wondering if statements like this in user instructions are normally ignored?
Many thanks,
Alex.
Many thanks,
Alex.
