I realise there is a post on here similar to this..but not the same.
Although this is posted in the UK board I am in fact in Cyprus ..where the leccy is a very similar sytem.
I want to put in a double external waterproof socket..and there is a single socket on an inside wall perfectly placed for the job. What I cannot work out is if I can use it safely.
The house was built about 12 years ago and has a "modern" trip-switch type consumer unit. Having taken the cover off the socket I want to utilise it looks like a spur ..ie only one red and one black wire to the socket. But the socket I refer to has its own trip switch (16A rated) ....i.e there's no other socket e.g on the ring mains (x2) which is affected when switching off this trip switch...just that one socket
Obviously if this socket that I want to take a feed off was a spur off the ring main I wouldnt use it for another spur in effect..I'll make a lot more work but take a spur off a socket that is on the relevant ring main.
However given that it has its own trip switch doesnt this mean its directly fed from the main board and that its safe to add a double external socket to it?
