I have a seperate circuit for my hob and oven. I believe the wiring on each to be 6mm2 (measured as 7 strands of copper wire approx 1mm dia for each cable)
My questions have arisen as I am about to replace the oven and want to make sure all is OK:
1) I have no problems. The ceramic hob works reliably at full blast, but the consumer unit is rated at 20A for both the hob and oven circuit- Is this too low?
(The hob is rated at approx 6.6kW, max 29A)
2) Does the oven need a specific isolation switch that says 'cooker' on it rather than a normal double pole isolation switch?
(New oven is rated at 4.4kW, max 20A)
Any comments
Any comments
