Over long screw and a fool
3 Nov 2006
Bedfordshire
For the last 6 years since building an extension there has been an un-connected switch outside the new bedroom door. It should have been the fourth switch in a four way for the landing lights. On Saturday I bit the bullet and put in the three core and earth to bring it into service. This work was prompted by the imminent failure of a 25 year old surface mounted architrave switch that was the end switch of the three way system. On Saturday this switch was replaced by an intermediate sunk into the door frame and the triple and earth run with the other cables up in the hollow of the door frame. While in a working mode I turned my attention to the beading on the door which, since having new doors fitted last year, was not in the best position requiring a hefty tug to close the door.
Carelessly or foolishly I used an over long screw and put the tip into the new triple and earth. Just enough to short the live carrying blue to CPC
At least for the replacement of the cable on Sunday all the holes in the joists and beam had already been drilled.
