    Dismiss Notice
padstone less than 150mm for over 3m lintel
Discussion in 'Building' started by chentong, 1 Aug 2020.
  1. chentong
    chentong
    26 May 2013
    3
    Thanks Received:
    Essex
    Country:
    [​IMG]
    As you can see the pad stone bearing (in yellow box) for lintel is 115mm instead of the minimal 150mm required.
    However, this is structural engineer's calculation, building inspector is happy with it.
    So maybe the rule isn't quite "150mm" length of the bearing but the actual area, maybe 15,000 mm2 (150mm * 100mm)? Can anyone with more expertise in this area help me to understand? It would be great if any reference can also be provided.
  2. Sponsored Links
  3. matlob
    matlob
    8 Jun 2017
    125
    Thanks Received:
    17
    Country:
    I thought the bearing is 100mm min so it doesn't fill the cavity?
    I'm having a 7m beam with 100mm bearing in each cavity so hope that is correct.
  4. chentong
    chentong
    26 May 2013
    3
    Thanks Received:
    Essex
    Country:
    Thanks Matlob, quite a few different places I googled on the internet suggest the minimal bearing each side is 150mm. But it could well be wrong understanding from my side.
    [​IMG]
  5. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    3,605
    Thanks Received:
    709
    Durham
    Country:
    The 150 is a good general 'shall be deemed to comply' number- a BCO looking at a lintel with that bearing won't bat an eyelid. Proper structural engineers (with professional indemnity) can specify whatever they can prove is safe through calculations (sometimes very specific to the job)
  6. 23vc
    23vc
    17 Apr 2015
    2,271
    Thanks Received:
    340
    Warwickshire
    Country:
    The 150mm doesn’t apply if it’s bearing onto a wall at right angles to it. So it’s a brick width’s worth.
  7. chentong
    chentong
    26 May 2013
    3
    Thanks Received:
    Essex
    Country:
  8. Sponsored Links
Loading...
Share This Page
