If as part of alteration work, notifiable Part P work is done, but not checked prior to covering up, how will this be checked on any regularisation application?
Can the cabling be checked by removing fittings, or will walls have to be opened up for physical inspection?
Also if some cabling is found not to be in protective conduit, and slightly less than the required 50mm depth, will the wall have to be opened up and conduit fitted?
Finally, if there is existing cabling, but nothing to do with the notifiable work, and this is covered up within plasterboard, would this have required protection too
Basically the cabling is on a wall which has been subsequently dry-lined
