Part p
MPB
21 Sep 2005
Leeds
Does my installer of my new combi need to be part p reg?.He has made no mention that he is.He will be running a new wire to the room stat and wiring the boiler up? :eek:
...funy could not simply reply to this post.....
how about u ask a sparky.
i think he can wire up to a fused spur thats already there...say from the old boiler ?........not sure if he can connect up a new spur
Anyone can connect a single spur onto an existing ring. Part p not needed. According to the ODPM heating system wiring (programmer, pump, thermostats etc) is fixed wiring and is part p. So you can connect a new outlet onto a ring, but you can't connect the heating system to it. Effin stupid?
Thanks for the replies guys, so to sum it all up he needs to be part p to carry out the work?.Will he have a certificate or something?. :(
Thats not the picture I have of the situation. AFAIK after checking with corgi is that anything after the fused spur is the plumbers domain.
Changing a switchplate for a fused spur doesnt require part p either.
Roomstats are nearly always low or 'zero' voltage so anyone can usually fit those.
Running a new fused spur into a ring main or breaking into a ring main to fit one is part P territory and can be got round by running 3 core double insulated flex to an existing fused spur located [loosely speaking] anywhere.
