Not sure if ths is safe. I want to fit a pendant in a shed. to avoid all the hassle with breakers and wiring i wondered can you mount the pendant run 2mm flex down to a 10amp MK switch and down to a 3 amp plug. Will be earthed. Is this legal and would i have to get it inspectected by an electrictian. also the switch is single pole so can i use a ternimal block to join two neutrals
Thanks in advance
Thanks in advance
