    Dismiss Notice
Perplexing plumbing puzzle - please pacify problem!
Discussion in 'Plumbing and Central Heating' started by Jonny2207, 18 Dec 2019.
  1. Jonny2207
    Jonny2207
    31 Mar 2016
    7
    Thanks Received:
    Country:
    I moved into a new build around 18 months ago, and I consider myself a competent DIYer. Before I ask the builder to come and look at my plumbing I wanted to get some opinion on an odd issue we've been having.
    Our showers don't get hot (we've got two of them). It was most noticeable (probably because we used it more often) on one that the other. To the point that we asked Bristan to come take a look. 3 visits later, after replacing the cartridge and then the whole mixer unit, it is still the same. And we've now noticed the other shower is now much the same.
    To add intrigue to the problem, the showers do get hot if you run a faucet tap first. I have tried this in different combinations with showers on/off and taps on/off and watched what happens to the screen on the boiler.
    This is the results (with no other water sources on in the house):
    Shower on > tap off: No activity on boiler
    shower on > tap on: hot water on
    tap on > shower on: hot water on
    tap on > shower off: hot water on
    So it seems that the shower on its own isn't 'drawing' enough water to kick start the boiler. Is that a thing?
    The boiler is a 35kW Ideal Combi.
    HELP ME! I'm going mad.
  2. Sponsored Links
  3. Chris_W
    Chris_W
    26 Sep 2019
    6,090
    Thanks Received:
    1,598
    North
    Country:
    Yes, it does sound like there’s not enough flow for the boiler to recognise a hot water draw off. I’d be getting the builder back. You might even have crossed connections.
    • Thanks Thanks x 1
  4. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    3,993
    Thanks Received:
    803
    Durham
    Country:
    There may be a pressure restrictor in the shower- have you still got the paperwork?
  5. durhamplumber
    durhamplumber
    23 May 2010
    14,279
    Thanks Received:
    640
    Durham
    Country:
    Is your stop tap fully open?.Or as said. .crossed connections somewhere..or dodgy mixer taps
  6. mattylad
    mattylad
    27 Apr 2008
    7,832
    Thanks Received:
    569
    Country:
    Is the isolating valve for the shower water connections fully open?
  7. Sponsored Links
  8. terryplumb
    terryplumb
    8 May 2017
    5,601
    Thanks Received:
    1,133
    Country:
    You stated that you used one shower more than the other ,and have lived there for 18 months ,so I assume the shower must have worked well for a period ? If this is so and your problem surfaced more recently ,I would suspect a problem with the boiler ,not shower valves that have been replaced.
  9. algas
    algas
    18 Oct 2008
    848
    Thanks Received:
    167
    Devon
    Country:
    My Daughter had a similar problem when she rented a flat that had just been re furbished, after three visits from different plumbers I went for a visit She in London me in Devon, the shower flex was one from an electric shower, internal bore about 6mm and the head was no better, I replaced the flex with a 12mm internal bore and drilled some extra holes in the shower head,hey presto works fine, the old set up wasn't allowing enough water through to trigger the flow sensor on the boiler, she asked the agents if they would pay me to fix it, that was a negative so when she moved out she took the new parts and left the shower not working for the incoming tenant, I wonder how many visits from plumbers it took to sort it, should have just paid me!
    • Thanks Thanks x 1
    • Like Like x 1
  10. Jonny2207
    Jonny2207
    31 Mar 2016
    7
    Thanks Received:
    Country:
    All, thanks for all of your advice. I hope you don't think i'm ungrateful but i haven't checked this thread for a while after I took "The Novice"'s advice and contacted the plumber that fitted the boiler. Its now resolved but I though I should post the solution in case others have this same problem.
    Short answer: It was the pressure reducing valve from the mains, located under the sink, set too low.
    Long answer: It was set to just a tad under 2 bar. It seems that this was sufficient for the plumber to sufficiently ensure that the showers were working - when originally fitted! All it then took was a little timescale on the shower heads, in the pipes, etc, to start to reduce the flow rate. The plumber only diagnosed this on the second visit, after we cleaned the heads, removed the flow restrictors, etc. on the first visit. It worked when he left but it was still temperamental - working better when the shower head was below the height of the mixer bar.... BINGO!.... the flow rate was still too low (but only just).
    So we changed the pressure reducing valve to 3 bar and everything works perfectly! Only took 5 visits from plumbers to sort out such a simple problem. If i can help others avoid this problem, then great!
    • Thanks Thanks x 1
    • Like Like x 1
  11. Jonny2207
    Jonny2207
    31 Mar 2016
    7
    Thanks Received:
    Country:
    Whilst I appreciate why you did this, I do feel very sorry for the incoming tenant!
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
