I think the dealer is referring to the carbon canister itself....the purge valve, I believe is a separate part. All it does is to allow the engine to ingest fumes from the petrol tank from time to time.
John
John
HI, as a pure matter of interest, did you find the problem?.hi, i have a 2001 peugoet 206 1.4 engine, when startin the car the idle usually heads up to around 2500 rpm, then comes down and sits at around 1100 rpm, on coming down it stutters at around the 2000 rpm, the car surprising drives well, apart from when stoping at a junction the idle moves at between 1500 rpm to around 2200 rpm, any ideas on this, has been to 2 seperate car garages who are out of ideas, so far have replaced all the fault codes which were lamba sensor, fuel injector number 4, and also the idle cont valve has been changed, and yet still the same. any ideas would be greatly appreciated thanks.
thanks got part this morning and fitted it, worked a little better, but aint gona say 100% fixed the problem. should it work straight away or is it one of these things that may take time to settle in, thanks
will i be able to get one of those at any auto parts place or you think will be a peugeot shot again, any ideas on price of these, where would this be on the engine thanks
