installing a WB 24i junior (25KW) into an older property that has 15mm pipe at present to cooker (adjacent to boiler position) that can barely supply the cooker.
approx distance from meter 25m (inc allowance for 8 elbows)
now it should be easy using the tables etc but i am only confusing myself..
can someone confirm that as the cooker is being removed if i repipe in 22 then that should be adequate ...
