OP what size cable have you got to the building ?
Sorry which cable are you referring to?OP what size cable have you got to the building ?
I would be happy with electricity for heating, but it's so expensive compared to gas
Apologies if I wasn't clear in my OP, but the electricity cabling, water and gas have not been connected as the building process is still in early stages, hence I was trying to decide what to do.The one from the house to the new outbuilding
Wouldn't PP be better than copper as it will be buried?It would be run in copper,
Not sure the OP specified it was to be buried, though may be an idea over that distance.Wouldn't PP be better than copper as it will be buried?
Apologies but I'm unsure what you mean and what is F&R?Just buy a 100m coil of 15mm speedfit some decent lagging and run 4 lengths (H&C, F&R) in a ducted trench. If you want you use lots of hot water at once fit an unvented cylinder for main house use.
Not sure a domestic gas installer is covered to install buried PE gas pipe though, don't think it falls under GSIUR and the domestic ticket scope, would need to check through.
He said through a garden, so buried seems the obvious choice. Out of sight, and safe from damage, theft etc. (I meant PE, not PP.)Not sure the OP specified it was to be buried, though may be an idea over that distance.
F&R is Flow and Return for the heating. Burying the pipes underground will help protect against frost.
Ahh right, thanks very much for clarifying. Since the pipes would go underground, what sort of insulation would I need to ensure the pipes keep the heat for as long as possible?He said through a garden, so buried seems the obvious choice. Out of sight, and safe from damage, theft etc. (I meant PE, not PP.)
My comment was replying to Madrab's #8, a separate boiler in the new outbuilding, with buried yellow PE gas pipe.Since the pipes would go underground, what sort of insulation would I need to ensure the pipes keep the heat for as long as possible?
So in that case the only choice I have is either get a gas pipe pulled and have a combi boiler or all electric?You need to be very careful about running extra 15mm pipes out that kind of distance to then supply 3 radiators.
I wouldn't ever use or recommend 15mm pipe to feed 3 average sized radiators (what sized are the proposed rads?) in the same house, never mind 19m out and back to an out building. Could cause all sorts of balancing issues in the mains house and in the outbuilding if they would actually heat up properly at all.
