Any help would be appreciated.
Got a 42" inch plasma and looking to fit this to a plasterboard cavity wall. I don't have access to the cavity from above or behind without taking down drick. I have worked with several types of plasterboard screws and found that they are not acceptable to hold this weight and don't want to take the chance of it falling down. It's a new build and as yet I haven't measured the distance between the studs and not sure if the actual studs are strong enough to hold any screws/bolts that I will use to attach the brackets. Based on the above any advise on how I should approach this job.
Cheers
Cheers
