Plasterboard wall fixings
19 Aug 2010
Luton
Hi all, I have to fix a 10kg electric radiator to a wall that seems to be made entirely of plasterboard (i..e. no cavity).
Which wpuld be the best fixings to achieve this?
Thanks, Chris.
No. It is a 60mm thick internal partition wall in a flat between a kitchen and a bedroom. Looks original.
I had thought to use GeeFix fittings but when I drilled the 25mm hole I found no cavity.
Is ''no cavity' a normal drywall method?
I
You are going to hate me for saying this, but on the types of partition walls I am talking about the manufacturers advice is that the walls are not structural and that all shelving, furniture, etc must be free standing.
No. It's good to know the truth. That's why I post on this forum. Thing is, I've already bought the radiators and 3 of them are up already (rawlplugged into brick). My research suggests the 'shear strength' of the screw in type of anchor I referenced above is around 7.5 kg. So with 2 brackets, I imagine 15 kg could be supported -1.5X the weight of the radiator.
I'm minded to give the screw in anchors a try.
I had something similar in a previous home. I think it was just three plasterboard sheets stacked together.
If it were me, I'd probably mount the rad using long bolts/screws right through the wall and into a batten (or possibly a wall cupboard) the other side. A cupboard would have the advantage of counter-balancing the rad's tendency to bow the wall.
