plugs left on
6 Dec 2005
Hertfordshire
is there any device that will show me what plugs are turned on from one location,twice i have found the hair straighteners left on and the iron
Not heard of anything either, but yes I know it's a common problem. One option would be to have all the vital items like fridge freezer etc on a circuit, and then have a contactor to turn off all other sockets (or selected few where certain items like straighteners and iron are used,) when you go by out having a switch by the door.
This has problems and would likely need some configuring of existing wiring, but is an idea.
You can get remote controlled sockets, I wonder if there is a kind that will tell you on the remote what outlets are still on
there are plenty with neons built in to the switch, but when you say 'light up' how light do you want it to be?
That takes me back, it reminds me of a freezer we had from Bejam.
One option:
http://www.green-plug.co.uk/info-green-plug.html[/QUOTE]
I like the look of that a lot, what I don't like is the fact you cannot set the time yourself, you'd think it could be achieved with a rotary control like on PIR's
One DIY (bit of a bodge) technique could be to plug in a two way unswitched trailing extension lead, cable tie a table lamp/nightlight etc into one of the sockets and then allow your wife to use the other for her straighteners
Do what I do. Run around after the wife turning things off. I also routinely check the back door which is invariably found to be unlocked. :rolleyes:
