Plumbers overspecifying boilers
Status
Not open for further replies.
Doitall wrote
The expansion vessel cannot fail, unless some clever idiot decides to weld it together.
Or isolate it from the system as an incompetent would do. Then you have the potential for failure.
Not one persons alive or dead has been killed by an un-vented cylinder in this country
Well it would be pretty difficult to kill them if they were already dead.
The fact remains it has happened and will happen again.
Or use a Megaflow which doesn't have an expansion vessel.
Quote:
How many people have been killed by an un-vented cylinder in this Country.[/quote]
Answer None
Incorrect. See below..............
If pressure equipment fails in use, it can seriously injure or kill
people nearby and cause serious damage to property. Each
year in Great Britain, there are about 150 dangerous
occurrences involving such unintentional releases. Around six
of these result in fatal or serious injury.
They are not talking about un-vented cylinders and you know it.
No-one has been killed by an un-vented cylinder in this Country, if you know different then prove it. because you cannot.
Well it would be pretty difficult to kill them if they were already dead.The fact remains it has happened and will happen again.
As above no-one has been killed by an un-vented cylinder in this Country.
The weld by the way is the strongest part of any mechanical joint.
The boiler does Drivel.
And not even you can belief an DIY would take the boiler to bits so he could doctor the expansion vessel.
This one is interesting. Note the expansion vessel is isolated from the cylinder via a filling loop and the isolating valve is in the Off position.
Very clever. One of your installs perhaps Doitall ??.
I wonder what else has been isolated or not fitted. :roll:
Im with Doitall on this one. The fact is no-one is able to provide evidence of a case where an Domestic Unvented Hot Water Installation has failed causing injury. Repeated quotes of the same passage lifted from the HSE do not supply this evidence. Pressure equipment is a generic term and can equally apply to any apparatus thats works under pressure, be it air, steam, hydraulics et al.
Maybe rather than putting down anyone who doesnt share your opinions, you could help the OP with his original query, and use your obviously superior intellectual abilities to help him design his system.
ballski This one is interesting. Note the expansion vessel is isolated from the cylinder via a filling loop and the isolating valve is in the Off position.
Interesting choice of pics balski :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
You are aware thats an store and not an un-vented cylinder, that pipe with the filler loop is to fill the outer chamber.
Some silly bugger has put it in on it's side...Drivel, is this one of yours?
The heat source Drivel.
Even an DIYer knows you have to have an heat source or it cannot overheat :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Status
