- Joined
- 14 Mar 2016
- Messages
- 9
- Reaction score
- 0
- Country
We have recently moved into a house which came with a new condensing boiler installed Nov 2014 (the house had been renovated by a developer). From what I know of the properties history the boiler hasn’t moved position from where it used to be, but now that it is a condensing boiler the plume output is much more visible, plus now we are living here the boiler is actually being used.
The boiler is venting to the side of our house, 620mm from the boundary, so just within building regs and we do have a certificate for it. There is a fence between us and our neighbors about 1m high. Our neighbour has bathroom and toilet windows on the ground floor of the side of their house, plus two velux windows (without planning permission, probably not quite within permitted development) on the side roof. It’s quite a windy area and gusts of wind blow the plume around quite a lot. There is a flue deflector which I have set to send the plume forwards (away from windows) but the wind just picks it up and moves it in all directions.
Our neighbour complained about the steam blowing around the two velux windows so I got a plumber out to investigate. He said we could install a plume management kit to move the plume upwards but that this would actually move the plume nearer to the velux windows so would not make the issue go away. We communicated this to the neighbours (plus mentioning that they don’t have planning permission for the veluxes!) and they changed their complaint to be about the steam travelling around the ground floor windows. They got a different plumber to come round and suggested (it was neighbours idea not the plumbers) that we divert the steam down a pipe for about 5m to vent over our patio and next to their conservatory/patio area, which also has windows which open. I’m not convinced about this because a. it wasn’t the plumber’s idea and b. it would cause a potential issue around both our patios and their conservatory. While they may be happy with this who’s to say they won’t sell up and someone move in who values their conservatory windows not having steam around them over the toilet/bathroom windows!
I do want to resolve this issue to the satisfaction of both parties (!) but am struggling to come up with what is the best solution to the problem. I’ve come up with the following ideas but could really do with some help on which is best/whether there are any other options or potential problems I need to consider:
1. Divert plume upwards – neighbours are not happy with this idea, would result in steam blowing around their veluxes and our upstairs landing window. However, would probably give us most protection against an actual environmental nuisance complaint, as the plume would be furthest away from any windows.
2. Divert plume backwards – could a 5m pipe cause any maintenance issues (could leaves etc. get trapped in it), would it just be moving the problem to a new area? This is not moving the plume up at all so would not disperse any quicker? Also, as gusty area wind will just blow the plume back down the sides of the house.
3. Divert plume forwards – we are in a national park so would need planning permission, planning office has not said it’s a no but their preference is for a side or rear output. Also, diverting the plume forwards with the flue deflector hasn’t stopped it from being gusted around everywhere.
4. Put up a taller 2m fence... so that I can’t see the neighbours any more… haha not really… thinking that this could maybe stop the steam blowing straight over onto their property, it would be forced to be above the height of the fence? It might stop it blowing around the ground floor windows?
5. Call up planning enforcement about their velux windows, maybe they would be forced to have them screwed shut and we could then go back to option 1. Not likely to result in friendly feelings!
I'm worried that whatever we do will leave the same or a different problem so any suggestions gratefully received!
