Big question as electricians are we qualified to decide on fire precursors? As a 40 year old in old house all three bedrooms had a roof infront of the windows and there would be no problem getting onto the roof, at 8 foot drop to floor outside not really a problem, but as a 69 year old I would not want to use that route, and I don't have the skill or knowledge to say if they could or could not be considered as escape routes, seems window fitters did as all have the release to open wide to use as escape route, but as an electrician I really don't need to know, if there needs to be a designated route some one with the training will mark it up, and with 8 ways out of that house one would not designate all 8 as escape routes.
As to plastic there is thermal plastic and thermal setting and the old Wylex fuse box has never had a problem with fire to my knowledge, even with the wood base, and the Electricial Safety Council show a picture of one saying how it can still be used, being plastic and no RCD, so to say they are wrong is sticking ones neck out somewhat.
I have over the last month seen so many posts on EICR, most around code C2, and what I can't decide is do we need a C2? Yes it may seem extreme, but what can the courts do if I issue a C3 instead of C2, one has still highlighted a problem, all 230 volt is protentialy dangerous so rather a silly phrase, and can't really see how any inspector can be said he was wrong never to issue a C2?
So if C2 is causing problems, simple, don't class anything as C2, either give it C1 or C3.
There is a picture of rubber cables on a light fitting in the guide 4 which it says C2, really, once disturbed likely C1 as it could go on fire at any time. Yes had this with mothers house and did wait a year before full rewire, but I was taking a chance, and with some one elses life should we take chances, I would say all rental property should have RCD protection, but that is my personal view, not what BS 7671 says, it allows continued use without RCD protection if not asked for when designed, so I can recommend fitting one, C2 but can't really give it a C3 even if I really strongly think one should be fitted and have done so with my own house.
So just don't use C2 simple.
