potterton netaheat electronic 6-10
30 Apr 2007
I seem to be having a problem with this boiler when i switch it on the fan comes on but the pilot light doesn't, i thought this might be due to the fact that the pcb was covered in dry joints but i have resoldered these but there is still no ignition :( any help would be greatly appreciated
Dont mess about with this boiler unless you know what your doing, please.
Hear hear!
Am a bit reluctant to give advise on this appliance, unless you can prove your compentency to work on it.
David
Here here again
these are nasty little beggars
if you dont know what your are doing you will endanger people if you work on it
Please get someone in
It sounds as if he is doing it for someone else!
CORGI number please then we will tell you all you need to know!
Tony
The back of these boilers are notorious for perishing due to little leaks where the pipes are connected to the boiler.If there is any signs of corrosion then the boiler could leak dangerous fumes into the room.DO NOT attempt repair if you not corgi registered.You could kill someone.
