Potterton Profile 50e not firing/no sound
Discussion in 'Plumbing and Central Heating' started by bobsingh, 17 Feb 2016.
  1. bobsingh
    bobsingh
    17 Feb 2016
    8
    Thanks Received:
    Country:
    Hey everybody, so recently my boiler has started giving a hard time.
    I went out the other day (mind you it was extremely cold) and when i came back the boiler wasnt working as good. The downstairs rad were cold and upstairs were just about warm but still had flowing hot water through the taps. I checked the pump, all good, and the rad were bleeded out.
    Fast forward a day and the boiler is not firing up at all and no hot water or rad working. Like even if you turn the knob, you dont hear that clicking/ticking sound its as if the boiler is completely dead; its control box is still working (that separate white box thingy) and can still hear the pump moving water up to the tank so i am assuming the fuse hasnt gone? Can someone please help? I am a complete novice so some advice would be nice, before i dish out on a new boiler!
    Thanks in advance
  2. Sponsored Links
  3. 75pete
    75pete
    9 Apr 2008
    664
    Thanks Received:
    61
    London
    Country:
    Bob, start by checking the overheat.
    When was this boiler last serviced?
    You say " boiler was not working as good" what do you mean by that?
  4. Aquaheat
    Aquaheat
    19 Nov 2007
    3,088
    Thanks Received:
    591
    Lincolnshire
    Country:
    EDIT: For some strange reason I read Suprima! Advice not relevant
    Jon
  5. Aquaheat
    Aquaheat
    19 Nov 2007
    3,088
    Thanks Received:
    591
    Lincolnshire
    Country:
    Sounds like the boiler had not long stopped working so there was still residual heat in the rads and cylinder that was lost after a while.
    Jon
    Edit: sp
  6. bobsingh
    bobsingh
    17 Feb 2016
    8
    Thanks Received:
    Country:
    It was last serviced about a year ago and it was working fine up until two days ago.
    Check the overheat? What do you mean by that, if you dont mind me asking, if so how do i check it?
    By the boiler not working as good, it was heating up as usual. I mean the boiler appeared to be working, but the radiators werent hot as usual
  7. bobsingh
    bobsingh
    17 Feb 2016
    8
    Thanks Received:
    Country:
    I will try the the above and will let you know!
  8. 75pete
    75pete
    9 Apr 2008
    664
    Thanks Received:
    61
    London
    Country:
    This boiler has an over heat reset. Look or feel and you will find a small drop down cover in the bottom cover. This little cover is only about the size of a finger. You can't do any damage by pressing the button once found.
  9. 75pete
    75pete
    9 Apr 2008
    664
    Thanks Received:
    61
    London
    Country:
    Ok, so the boiler was or is able to fire up. So you have lots of hot water but not hot rads? Is this correct?
  10. Sponsored Links
  11. bobsingh
    bobsingh
    17 Feb 2016
    8
    Thanks Received:
    Country:
    I just tried pressing the overheat reset switch and nothing happened
  12. bobsingh
    bobsingh
    17 Feb 2016
    8
    Thanks Received:
    Country:
    well yesterday it did fire up but only for like a minute or two but still provided hot water. Today its absolutely nothing, neither is it firing or proving any hot water
  13. bobsingh
    bobsingh
    17 Feb 2016
    8
    Thanks Received:
    Country:
    There is no fan spinning or humming, its just silent. usually you would hear a clicking when you turn the control thermostat but strangely there is none of that either
  14. Agile
    Agile
    26 Jun 2004
    64,039
    Thanks Received:
    4,595
    London
    Country:
    Isn't it due another service now?
  15. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,296
    Thanks Received:
    2,055
    Hertfordshire
    Country:
    Faulty 3 port valve.
    Andy
  16. Echo the husky
    Echo the husky
    25 Mar 2011
    2,476
    Thanks Received:
    326
    Devon
    Country:
    But the hot water isn't working either.
  17. oph
    oph
    20 Jun 2010
    8,784
    Thanks Received:
    1,519
    Sussex
    Country:
    Serviced a year ago. Id say its due its annual visit;)
  18. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
