Power breaker for bathroom Illuminated mirror
18 Apr 2007
Hi
I just mounted a illuminated bathroom mirror above my bathroom sink.
I got to wire the lighting cable up to the pull switch on the mirror. I take it is preferable to have a power-breaker (RCD) in line in which would minimise any risk. Would a RCD work in this situation?
Here's how I read the regs,,
All additions, alterations or new installations should be carried out IAW the current regs; the regs are also not retrospective, so existing stuff can remain as they were installed
Keeping it simple..
The current regs state that all circuits within a bathroom need to have RCD protection, any cables (T&E need to have RCD protection also if they are buried <50 mm)
So whilst your existing circuits / cables don't need to be RCD protected, the new cables you install do, although it would be better/safer to RCD protect the whole circuit..
Points to note..
Is your main earth the correct size?
Is your protective earth bonding up to size?
Do you already have RCD protection on the circuit?
Do you live in England or Wales??? If so this work is notifiable under Part P of the building regs!!!
The circuit wire was put in 1996 when all of the house was completely reloomed. At the time I didn't know what I wanted there & the sparky capped of the end of the cable, until I had decided.
Now I have the mirror up I want to unscrew the cap and fit the wire to the mirror.
So it's not really a new connection just a fitting of a appliance as such.
The circuit should have RCD protaction, as connected to a RCD Wylex consumer box, which is fitted.
So when your property was rewired the electrician left a connection plate for you to connect something to??
If so then you could just fit it, as you are as you say just connecting an appliance as such..
Without seeing your consumer unit it would be very difficult to tell wether you have RCD protection on your lighting circuit,, a picture would help!! I know RCD protection was a requirement for D/S sockets, but you didn't have to have it on any other circuit!, so you may have a split load cu or you could have a RCD main switch. :confused: :confused:
Correct; the electrician left a connection plate for me to connect too. So just got to connect up, there is no altering of the wiring required.
OK, all I know that hen I knock of the lighting circuit I just flip the RCD for the circuit up and it cuts off the lights.
The Wylex consumer unit is a few editions ago, as now 13 years old.
:oops: Are we talking MCB or RCD here ?? :eek:
If you dont know what I am am saying I suggest you call the electrician back to do/ and sign the work off for you. ;)
Ed
Sorry yes talking MCB, I don't have a RCD. Just got the 6 MCB and the main switch.
Do you think it would be worth while getting someone to upgrade the consumer unit?
ok cheers. But worthwhile to install a powerbreaker though?
An RCD yes. powerbreaker is a brand name. Other brands are available.
The mainswitch in your consumer unit - does it have a small test button?
