Hello. I have been advised by BG to have a power flush and from looking on forums not an an unusual suggestion. Does it does reasonable?
Situation is that I have a Worcester 35 CDi combination boiler. The problem is that whilst the hot tap tap is running the boiler intermittently shuts off and then short while fires back up again so for example you end up with a tepid bath.
BG have been done a number of checks, changed some sensors which has not resolved the issue. Engineer (after discussion with BG and Worcester support) believes that some debris is reducing flow through the boiler and therefore water temp rises too much much and therefore shuts off.
He recommends that a power flush should clear this debris. Having checked my radiators some of them do indeed have cold spots at the bottom suggesting there may well be sludge in the radiator. However the central heating side of the boiler seems to work fine and have not noted it shutting off intermittently when the central heating is running.
My question is that will power flushing the central heating "side" of the boiler help with this issue which seems to affect the hot water "side" of the boiler?
