PowerMax Complete External Siren - MCS-740
21 Nov 2016
Afternoon all,
I've recently had the Visonic PowerMax Complete installed into my home, however I have noticed the LED does not pulse to indicate the external bell box/siren in on. So in the dark you can barely see there is an alarm fitted. I believe I can activate this by flicking the LED KEEP ALIVE jumper in the bell box.
First off, is this correct or will i need to buy a seperate self sufficient LED light to go in the box?
Secondly if I did want to do this will I trip a tamper alarm? If so can this be easily deactivated using the fob or entering the code on the panel? Or is there a way to set it to ignore tamper on that box until I've finished?
Any help would be appreciated.
Thanks,
28 Nov 2016
You are correct, the LED Keep Alive is a jumper within the bellbox - will give you 5 sec interval blink. I would say you need the practice to change the batteries but they should last 3 years so get the ladder out!. It will only give a tamper warning at the control box when disarmed anyway.
2 Feb 2016
Newark
Turning the led on a wireless bell box will cause the battery in the bell box to go flat quicker and you will need to keep replacing the battery...
8 Feb 2010
Hi, powermax is a great alarm but I would strongly advise against using the LED jumper as it will reduce battery life to around 12months....
We ALWAYS use LED kits
Been using them for nearly 3 years...not had one battery issue yet!!
thx
Matt
