Oh yea maybe there could be deceiving loop behind the barI only see 2 in the N1 bar?
Indeed - but, as I went on to ask, which of the 'standard tests' (per, say, an EIC), the undertaking of all of which which would probably be regarded as adequate/acceptable, would have detected the problem with the neutral(s)?Mistakes are not supposed to go undetected before they bite. That's why we have tests, checklists etc.
Maybe, but it was a serious question. How common is it to undertake, in addition to all the 'measurement' tests, a functional test of every final circuit?The one that checks for incompetent dunderheads?
There is another wire in terminal 14.Mm, did you install this yourself ? Remove the U link in the Neutral bar ……..
DS
Well, that begs the question as to what regulations, other than the most general and vague ones, would require functional tests to be performed.Well, I would point to 610.1: Every installation shall, during erection and on completion before being put into service, be inspected and tested to verify, so far as is reasonably practicable, that the requirements of the regulations have been met.
