- Joined
- 27 Mar 2017
- Messages
- 28
- Reaction score
- 1
- Country
Hi all,
First post here, I'm new to alarms but I've been reading up on these forums for the past week or so and I'm wondering if someone could help me a little bit.
I'm about to move into a new property and I would like to install an alarm, it has to be wireless as there is zero chance of a cabled install without it making a mess. I don't know much about alarms, so I nearly ended up buying a Yale Easy Fit Kit (Standard or Telecommunicating). Then I did my research and found out about the bands (433 & 868) so I wanted to get a newer version that used 868...then eventually read up on "Grades" and decided I would rather spend £500 on a proper system, than £150 on a pap system.
So.....after doing a bit more research and nosing round these forums, I quite fancy this;
http://www.map-security.com/pyronix...th-digi-wifi-communicator-app-kit-1-wifi.html
I wanted to get the Yale Smart Alarm the can connected to the internet, so I could check the system remotely etc, so I think this will do the job, I do have a couple of questions if someone wouldn't mind indulging me;
Thanks in advance!
- Is this kit above complete? or do I need a something else? (other than the 2 extra window sensors I need to purchase)
- How difficult would this be to install for an amateur? I work in IT and I'm fairly technical, I can follow a set of instructions at least
- I've come across a monthly/yearly fee to access the Pyronix cloud, which in turn will allow access to your system remotely? How much is at the moment as I can't seem to find this information on their website anywhere? Also, do you have to use the cloud service? I'd much rather VPN to home and access the panel locally rather than have it cloud connected
Thanks in advance!
