B
breezer
a pint rests on the correct answer to this one
a 400 gallon water tank fitted at say 20 feet up ona a wall has two pipes coming from the bottom. one is 15mm the other is 40mm diameter
the pipes run verticaly down the wall to the floor, at the floor each has 2 90 degree bends (to make a u shape)
the tank then has a plug put in each pipe, plugs are chained together.
tank is the filled with water
when full, chain is pulled (so both plugs are removed at same time)
question.
will the water forom one pipe (at the bottom) go higher up that the other, if so which and why.
i say no because although different diameteres they both have same pressure
question.
