Posted from another forum:
Please sign if you feel cause:
http://epetitions.direct.gov.uk/petitions/37408
Who's going to end up in the brown stuff when a sparks pulls a cutout, something goes wrong and he dies? I can see where the petition is coming from, but it's really completely unworkable to allow every sparks to remove cutout fuses.
I have seen many a main fuse be pulled by the DNO and bar the odd one or two the majority of them never wear PPE when pulling
Even when the fuse is pulled I have seen loads of them just use insulated drivers to ensure the supply bottom terminal is tight once the fuse is removed.
Not necessarily - the buck can stop at the directors for H&S violations.If they choose to ignore safety rules and it goes wrong, on their own heads be it!
Indeed not - what I meant was that sacking the numpty (or what's left of him) might not leave the directors free and clear.Agreed as they have a duty to enforce the rules which is done via audits, refreshers and annual competency tests.
It still doesn't stop someone losing his/her job though which has happened
Very much so, in particular the question of which legislation the petition is asking to be revised (or introduced). Even if one felt that the fuse pulling was a good idea, is there actually any currently legislation which explicitly outlaws this? (and, if not, what on earth is the petition asking government to do?) As for a requirement for fitting isolators, I'm not at all sure what current legislation that could logically be added to, so it might actually require new legislation. As you say, the petition has not been properly thought about.The petition needs more thought and properly writing out.
