Motorbiking, Do you have a screwfix by you? If not where would you shop. We can probably do you a shopping list if you want.
What is the best way to get the lego lock fittings off. Attack them with a screw driver or do they unscrew ? i’d rather not cut the plastic pipe any shorter
Possible but I am assuming a bit of movement possible as he managed to get the pushfit in.but there was literally no play in the copper,
You can cut the grab rings with a pair of wire cutters which will simplify removal.
2 x stainless steel liners
Don't think you will need 4 x compression sockets but you can always take them back.
2 x stem elbow (s/fix 20071)
Motorbiking, too many cooks on this thread, another question.... what bike you got.the liners go inside the plastic pipe to stop the compression fitting crushing it?
And just a worry, you know that you need liners for plastic pipe and push fit fittings don't youthe liners go inside the plastic pipe to stop the compression fitting crushing it?
