Hi there,
Sorry, this is a bit of a lengthy first post but I am going mad here!!
We are having major issues with sourcing a replacement oven for our old Baumatic that died recently due to the location of a gas pipe in the oven recess. To cut a long story short our only option left is to purchase the same oven again. Looking at the user manual, the oven says hardwire only and yet the oven we just took out (which was there when we moved in) was simply plugged into a standard socket in one of the adjacent cupboards.
In the manual it states:
"Before connecting the appliance, make sure that the supply voltage marked on the rating plate corresponds with your mains supply voltage.
Warning: this appliance must be earthed.
This appliance should be wired into a 13 A double pole switched fused spur outlet, having 3 mm contact separation and placed in an easily accessible position adjacent to the appliance. The spur outlet must still be accessible even when your oven is located in its housing.
To connect the oven power cord, loosen and remove the cover on the terminal block, in order to gain access to the contacts inside. Make the connection, securing the cord in place with the cable clamp provided and then immediately close the terminal block cover again.
If you have to change the oven power cord, the earthing (yellow/green) conductor must always be 10 mm longer than the line conductors.
Care must be taken to ensure that the temperature of the mains supply cable does not exceed 50°C.
If the mains supply cable is damaged, then it must be replaced by an appropriate replacement which can be obtained from the Baumatic Spares Department."
If the fuse requirement is 13A can I not just attach a standard 13A plug to the power cable and use that? Hardwiring would be a major undertaking due to a tiled kitchen, a concrete floor, and big thick masonry walls.
Thanks in advance for your help!
Grant
Grant
