Pyronix Enforcer (V10) - Night set with a fob
25 Oct 2020
Hello all,
Can anyone help.
Looking to use my key fobs to set ZONE B (Night set) and set it to bottom position I. I have been over the setup loads of times, but the fob is not liking it.
Any ideas?
Mike
Default B ( night set ) is I ....unless you have messed with the fob settings in engineer mode .!
Cheers for that. If I use my engineer code to set B it works and it will set on night set . It's just the fob.. all other buttons work.
By default I is night set and the bottom button II is alarm status. So you need to check the settings if you’ve changed them
Hi again,
Would that make a difference?
I have 2 fobs and 1 tag programmed. Both fobs are set the same (but will double check)
Assuming you mean the fob with the four buttons then as follows - Enter Engineer Code > Wireless Device Control > Program Key Fob Buttons > Select User > Yes Select Button I or II > Set Area > Select / Press B then Yes. Exit Engineer Mode.
