but surely you are doing a Bernard and guarding against the Blue Moon event rather than the more likely events when you would not want them joined.
If a person can touch ( or be in contact ) with two conductive items either or both of which contains electrical circuitry with a supply that is referenced to ground ( Neutral to Ground bond at the substation ) then the Blue Moon is that when one item develops a fault that raises it's potential and the other item has a path to ground ( water pipe etc ) that has some impedance. The person who touches both gets a shock if the items' touchable conductive surfaces are not bonded together.
How severe is the shock ( how many milli-Amps through the body ) and what is the duration of the shock that occurs because the items are not bonded together.
A short severe shock ( time limited by the RCD tripping ) is less harmful than a prolonged mild shock when the RCD does not trip as the impedance to ground ( water pipe etc ) limits the shock current to be less than the RCD's tripping current.
If you doubt a short severe shock can be almost harmless then consider the shock from a defibrillator. The defibrillator gives a short and severe shock that stops the heart fibrillating and then allows it to self restart. The duration of this shock is too short for any significant electro-chemical damage to occur.
