I assume that you have to fit a double pole rcbo at the consumer unit to protect your sockets as they may be used outside in the garden , ie in the event of a fault both the live and neutral are isolated , would you be allowed to fit a single pole rcbo for sockets ??
I am trying to understand what difference does it make if you only cut the live conductor (if you used a single pole rcbo) as the live would be dead in the event of a earth fault and the danger should be gone . Why is it any safer if the neutral is cut as well ???
It removes and danger associated with reversed polarity wiring, and also removes any chance of a dangerous potential existing between earth and neutral, although this is very unusual.
So still confused -i am thinking it has to be a double pole rcbo to protect the garage supply cable as with sockets in the house the rcd will switch off both the live and neutral at the same time .
Sorry , i was thinking about a garage supply cable at the time as i was trying to make the relation with outdoor circuits ie the sockets could be used outside.
So could i use a single pole rcbo to protect my garage supply cable or does it have to be a double pole rcbo ??
you dont need rcd/rcbo protection of a gararge supply cable generally, unless we are going into issues brought up by the upcoming 17th edition and even then it depends on the cable run/installation method.
why not a normal mcb for a dedicated garage CU housing rcbo for the sockets and mcb for the lights, or a common rcd.
I thought anything outside the house that is electrical ie cable should be protected by a rccd , what if the garage supply cable whic is a 6.00mm twin & earth protected by plastic conduit was damaged and it was'nt protected by a rcc back at the house.
