I've bought a rcd/mcb for a 8.5kw shower I've fitted, it says it is a c/w 2 pole, 63amp, 30mA rcd and 1x40amp mcb. What does the c/w mean and does the 63amp mean it will only take 63amps? All replies greatly appreciated.
Sounds like you have bought a small consumer unit. The 63A is the maximum current that the RCD is manufactured to handle. Not a problem if you are only using it for 40A.
Adding a C/U though is a notifiable activity under part p of the building regs, I just hope you don't live in copeland if you intend doint it yourself!
Since a bathroom Part P anyway. But where only one output then it is not a distribution unit it is only doing same as a RCD FCU so not so sure if it would require Part P notification?
It would I think depend on how it is supplied. If an existing circuit was cut and this inserted maybe not? Although new circuit will require Part P.
I'd have classed it more along the lines of a new consumer unit supplying a new final circuit, so a full IEC and part p notification are required.
Altering the circuit protective measures isn't minor work, it will require a full EIC and isn't on the list of non-notifiable activities for part p and hence is notifiable in itself.
Part P notification is definately required, it is a new circuit in a special location and the op lives in England.
You will sometimes notice, that it actually costs less to buy a two way Wylex 63 amp 30mA RCD consumer unit, instead of a standalone Wylex 63amp 30mA RCD by itself.
So that's the way to go - if you need RCD protection added to a shower, just buy the complete consumer unit, and just insert a 40, 45 or 50amp breaker into the unit, blanking off the other slot, and install it as usual.
